Doorbell battery won't charge it keeps saying it's empty
Miles64
The battery won't charge even though it was charged for 5 hours.I plugged it in the wall socket nothing kept a charge this is the second doorbell I've tried.
James_ADT
Did you check the Doorbell Transformer?
Thanks for reaching out. I'm sorry for the delay. To isolate the issue further, could you please try using a different cable for the charger if you have one. Also, try to test if the socket is working by charging a different device.
I appreciate your help, @James_ADT.
Hi Miles64,
zoeuvre
@Miles64, we haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
Thanks for your help, @James_ADT and Jenelyn.
All the best,
