06-21-2023 01:07 AM
I have had my Google nest battery doorbell for approx 6 months now and was working fine until yesterday when the camera went off line.
I followed all the troubleshoots and finally decided to press the reset button to put it back to factory settings.
In hope that the reset would allow me to set the doorbell up from scratch again I followed the set up options but cannot get pasted the connecting to WiFi set up for some reason it won't link to my WiFi. My WiFi has not changed position, other systems are running off the WiFi correctly, I have tried removing some of the other systems to allow more capacity and also rebooted my router several times.
When reading the set up options and plugging in the charger it tells me the door bell is fully charge but the light remains white and doesn't flash blue.
06-23-2023 01:18 PM
A lot of us are having similar issues. Latest app update is broken I believe. Camera lights are still reacting as normal and appear to be capturing footage. Just cannot view this in the new app. I started a similar thread as mine have been down for coming up on two weeks.
06-25-2023 01:31 PM
Hello everyone,
Thanks for posting — let's get this sorted out. Let’s try the troubleshooting steps below.
Let us know how it goes.
Lance
06-25-2023 03:37 PM
I appreciate the response @Lance_L but for me this is a huge pain. I had my cameras professionally mounted. So now I need to climb up two stories on a ladder to disconnect and reconnect my devices all around my property, because you guys broke an application with a faulty update? That isn’t easy for me as a disabled vet.
Others on here are stating this didn’t fix anything. Unless something has been fixed on the google end? I’ve been in IT for many years. I know all the basics
06-26-2023 12:18 PM
Hi JFSharpe42,
We really want to get your Nest devices back on track. Resetting them to default settings is the next best step. Give it a try.
@NickR9018, do you still need help? Don’t hesitate to reach out if you do.
Lance
06-29-2023 01:51 PM
I wanted to follow up and see if you still needed help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
Lance
06-30-2023 01:56 PM - edited 06-30-2023 01:57 PM
Hi everybody,
Just one final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
Thanks for answering, Lance.
