05-23-2023 10:52 AM
Nest doorbell inside chime doesn’t ring
settings field does not contain a toggle switch to turn chime on/off
05-23-2023 11:15 AM
The "Indoor chime" option under Settings for your doorbell in the Google Home app turns your indoor wired doorbell chime on or off.
05-23-2023 08:32 PM
Indoor chime setting is on. Inside chime still doesn’t work.
doorbell is chime is mechanical
05-23-2023 08:33 PM
Had to go through the nest app to find chime settings
05-24-2023 10:35 AM
If you had to go through the Google Nest app to find the "Indoor chime" setting, then you have the older Google Nest Hello Doorbell, and not the newer 2nd Gen Google Nest Doorbell indicated in your post.
Did your indoor chime recently quit ringing? Does your doorbell also go offline for a minute whenever the doorbell is pressed? If so, perhaps like many customers, the internal battery on your Nest Hello is now failing. It's happened to all 3 of our Nest Hellos.
Here is a very long thread with over 1,000 replies on the problem:
Since Google Nest says they "cannot" replace the doorbells, the workaround is to turn off the "Indoor chime" option (thereby preventing the doorbell from going offline) and instead turning on "Visitor announcements" (https://support.google.com/googlenest/answer/7672451) to get announcements instead on Nest Hubs or Nest Minis.
05-23-2023 08:27 PM
Gen 2 wired doorbell connected to mechanical chime. Indoor chime won’t ring
05-24-2023 10:56 AM
Is your "Indoor chime" option turned on?
Is your chime puck wired correctly as shown here?
https://support.google.com/googlenest/answer/12153643
If so, you could try contacting Support:
05-26-2023 12:07 PM
I'll merge this thread with the main post, where all the updates will be posted, so we can communicate effectively. You can follow the main thread for news because this one will be locked automatically once merged.
05-26-2023 12:10 PM
Hi Jesg,
Thanks for reaching out to us, and I appreciate your checking out some settings on the app. Let me take a look at this for you.
Have you checked if your Nest Doorbell battery is fully charged? If it is not, simply take it off the backplate and charge it with the included USB-C cable as this is one of the reasons why the Nest Doorbell inside chime doesn’t work.
I’ll look forward to your response.
05-29-2023 01:31 PM
Dan
05-31-2023 12:24 PM
Hello again,
Dan
