05-12-2023 02:50 PM
Hi, I am trying to install a nest doorbell battery and use the existing chime. The problem is that I have this Commax (DPV-4AE) Video Doorphone with Camera DRC-403DF. The chime+camera panel has four cables instead of the two shown in videos, presumably two for the chime and two for the camera. I have tried every combination of wires with no success, doorbell is always on battery and the chime doesn't work. I don't care about the Doorphone camera since I have the nest, but I need the chime to work.
Thanks
05-16-2023 05:06 PM
Hi jbraunll,
Thanks for reaching out. Try these troubleshooting steps and let me know how it goes.
Check out this link for more information.
Juni
05-17-2023 01:54 PM
Thanks a lot. I guess I have a more basic problem with the wiring. I have four wires and haven’t been able to get power on the doorbell.
05-17-2023 06:40 PM
Hi jbraunll,
Got it. Some doorbell systems have a built-in intercom, gate control, or a doorbell that's located far from your home (such as an outside gate). These systems typically don't work with the Nest doorbell.
In this case, there are a couple of options:
Juni
05-21-2023 03:36 PM
Chiming in — I just want to check if you were able to visit the link provided above. Please let us know if you still need help.
I appreciate your help, Juni.
05-22-2023 12:08 PM
Thanks, I did visit the links, but I am still trying to connect to the existing doorbell. I will keep you posted.
05-26-2023 01:53 PM
@jbraunll, how's it going with your Nest Doorbell? Were you able to connect with your existing doorbell? In case you have an update, let us know and we'll be happy to help.
Thanks for your help, Juni and Jenelyn.
05-30-2023 11:40 AM
@jbraunll, I wanted to check and see if you are still in need of any help. Please let me know, as I would be happy to assist, and answer any questions you may have.
05-31-2023 11:30 AM
Hello there,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
