04-06-2023 04:21 AM
Hi
sorry if this has been covered elsewhere, but I have had to fit a new transformer for my doorbell. It is wired in and all works but then after about 8 hours the power to it cuts out and the boor bell doesn’t work. I take wires out and re fit them and we’re working fine again for approx the same (8 hours or so).
Does anyone have an answer please??
thanks
04-06-2023 11:50 AM
Well, if your doorbell worked with the previous transformer and does not work with the new transformer, it would seem like it's due to SOMETHING with the new transformer.
04-06-2023 09:42 AM
Is your transformer compatible? As with many other customers, we upgraded our transformer from 16 V 10 VA to 16 V 30 VA a couple of years ago because 10 VA was insufficient even though it meets minimum requirements.
04-06-2023 10:22 AM
Hi. Yes I have replaced with the exact same one as was previously installed. It has worked since day 1 so no need to doubt it
04-06-2023 11:50 AM
04-12-2023 11:43 AM
Hey there Heisenbert,
I wanted to check in and follow up with things here. It looks like you were on a path to get this sorted out, but I wanted to make sure you had things resolved. If you're still looking for some input, just let me know.
Jeff
04-12-2023 12:31 PM
As mentioned, I have put it down to a faulty transformer. Put the old one back on and it works fine. Going to buy a different transformer in future
thanks
04-13-2023 10:44 AM
Thanks for the follow up, Heisenbert.
I'll go ahead and mark this question as resolved, but will leave the thread open for another day in case anyone has any additional input.
Jeff
04-14-2023 12:29 PM
Hi all,
As we got our resolution here, I'm going to mark this one as resolved in the next 24 hours. Thanks to all who helped and contributed. If anyone has any other needs, please feel free to let me know before the lock.
Jeff
