12-26-2021 09:31 PM
New to this Connected Home stuff…
Trying to decide if I should install a Google Nest outside camera and use my regular doorbell, or if I should just replace my regular doorbell with a Nest Doorbell and not install a camera near my front door?
Don’t they do the same sort of thing?
Do I need both or is just one of these Camera options enough?
Thanks.
12-27-2021 08:41 AM
Depending on the size of your home/front yard you may want to install both. I would start with the doorbell and see how much area is covered before adding the second outdoor camera.
12-27-2021 12:53 PM
Thank you for responding. That sounds like a good start.
12-27-2021 12:41 PM
Doorbell. And if you can find it, purchase the previous generation wired-only version. The 2021 version (battery) is inferior.
12-27-2021 12:54 PM
Thank you, Rubes. Good suggestion.
03-23-2022 09:18 AM
@Rubes thank you for your help!
03-28-2022 08:38 AM
Hey Folks.
