Doorbell: removal safety button stuck
Repeat64
On my Google Nest Doorbell Battery, the small button on the back that prevents the doorbell from being removed without using the tool is now stuck in the "pushed in" position. This now means that the doorbell can't be re-mounted properly and is not secured on the mount. Is there any way to get the button to jump into the "out" position? Using the tool it doesn't seem feasible. Please advise.
@Repeat64
I've seen other posts in this forum from customers who have the same problem. You could try contacting Google Nest Support; perhaps they're replace your doorbell:
8 REPLIES 8
@Repeat64
Thanks for your help here, MplsCustomer.
I'm sorry to hear that your Nest Doorbell (battery) can't be mounted to the wall mount and the pin is stuck. Could you please send us a photo of your doorbell battery so we can have a better look?
Hello MplsCustomer,
I've used your link and filed and RMA under warranty. The replacement unit is being shipped as we speak. So I guess the issue will be solved with this. Thanks for your reply!
janthadeus
Hi Repeat64,
Awesome! That's good to hear! Please let me know if you need further assistance.
janthadeus
It's me again. Checking in to see if you still need help with this. In case there are any follow up questions or comments. Please let me know if you need further assistance.
Hello JT,
A new unit was shipped under warranty and had already been fixed to my wall. The old unit is in its way back to Google. No further assistance is required, as my problem has been solved.
Kindest regards, Repeat64
janthadeus
Hi Repeat64,
Awesome, glad to hear that! Thanks for following up. We're here if you have any other questions.
aatienza
I appreciate the help, JT.
Archie
