Doorbell wired won't hook up to wifi
HDLee505
Doorbell wired is all wired up and blue light is on but will not finish setup.
6 REPLIES 6
EmptyNester
Silver Product Expert
One thing to check is make sure both WIFI and BLUETOOTH are enables on your phone.
Thezoo
Following.  I am having the same issue and none of the trouble shooting has worked this far.  Good luck.  If I figure out something I will follow up.
Thezoo
I messaged with support earlier and simply added a new home (same house) to Nest and it worked properly.  The old house can be deleted or removed unless you want to keep it because of other products.  Hope this helps or you have already resolved the issue.
tetryon
Support told me to do the same thing - but I have everything set up on my old home and need it to be all together. I don't want to go through the hassle of manually moving everything. Waiting to hear back from support.
@EmptyNester thanks for your help!
Hey Folks.
