12-04-2022 02:30 PM
I took the doorbell off to charge it, the pin the locates into the wall mount has stuck inside the body of the doorbell so I cannot remount it. This appears to be a fairly common fault. I've tried using the removal tool to pop it back out as suggested on another post with no luck. Thoughts?
12-08-2022 10:39 AM
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. Have you tried a pin or something small to try and dislodge it? What other troubleshooting methods have you tried besides what you shared here?
12-09-2022 10:19 AM
Yes I tried using a small object to pop pin out. No luck.
12-12-2022 10:42 AM
12-15-2022 12:10 PM
Looks like you have filled out the support form, so thank you for doing that. As support will handle this case, We'll leave this topic open for another 24 hours in case there are any follow-up questions or comments.
