Dropcam Pro installation
AML1618
I have dropcam (2014) won't install
I am using MAC Pro MACOS 11.6.2
Camera is seen by finder,  when I click on the install program,  nothing happens.
Have tried to re-set camera,  nothing happens
How do I install ?
Thanks
AML1618
8 REPLIES 8
SteveT1
We hear you. USB setup does not work on MacOS 10.15 or higher.
If you are using a Dropcam Pro, you can continue setup using the Nest app. If you are on Dropcam HD, I would suggest using a lower MacOs or a different computer for setup.
Hope this helps.
Steve
AML1618
Thanks Steve
SteveT1
Hi AML1618.
It's a pleasure.
Steve
SteveT1
Hi AML1618.
Thanks for the update. Have you tried installing using both the Nest app and by using a different computer? Did you get an error code?
If so, you can check this article on how to Troubleshoot Nest camera and doorbell setup messages.
Steve
AML1618
wont install...  says Dropcam Pro cannot be added to my account
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
