04-11-2024 04:46 PM
With all of my other cameras, I have the ability to look at full history while in the Google Home app. Anything between events within my doorbell feed do not exist. When I go to said empty space, I get a message that reads "The device was off-line due to empty battery." How is this possible with a hardwired doorbell?
04-16-2024 09:55 AM
Hi Srosst,
Thanks for reaching out! I'm happy to help you troubleshoot this inconvenience. To diagnose the issue effectively, I'd like to ask you some probing questions:
I'll be happy to guide you towards the best solution.
Manuel
04-16-2024 12:39 PM
The doorbell is less than 20 ft from where my AT&T fiber enters the house (where the router also is) and it's 10ft from where the Google Home WiFi router is. I believe the issues started a week ago.
the doorbell is hardwired to a router. The system has been in place with no changes since 10/2022
04-18-2024 01:11 PM
Hi srosst,
Thanks for the information! Based on what you've shared, I recommend performing a factory reset on your camera. After the reset, please check if the message reappears.
For instructions on performing a factory reset please visit Restart or factory reset Nest camera or doorbell.
I hope this helps!
Manuel
