Feature request: schedule for indoor chime
DaanvandenBergh
I know another user requested this feature 2 years ago, (@redningja) so I'm trying again:
I'd like a schedule feature for the indoor chime, so I can mute it at night.
There's currently a scheduling feature to turn the camera off, but I'd like to keep the camera enabled for added security. I'd just like to be able to disable the connected indoor chime on a schedule.
Thanks!
EmptyNester
Silver Product Expert
Hello,  I'm an end user like you and that is a great idea.   This is a user forum and Google does not read anything here.
Google is in the process of phasing out the NEST app but it is taking a lot longer than anticipated.  But i'm 99% sure they are not putting in any new features in it.  They are focused on migrating everything to the GOOGLE HOME app.  And in that app you can top on the GEAR and select the FEEDBACK option and let them know your request.
They are letting people migrate some of the nest cam models now but I  don't recommend doing it as the app has less features than the Nest app you are currently using.
