Floodlight motion sensor to control other smart lights
TimsSmartHome
Is it possible for the nest floodlight to trigger other smart lights coming on when it is triggered to come on itself? For example, a floodlight is mounted on the back of a garage facing an alleyway. On that same side of the garage, there are Philips hue exterior lights on either side of the garage. Given the size of the space, I’m wondering if it’s possible for the floodlight to trigger the hue lights to come on using the same motion sensor.
EmersonB
Hello TimsSmartHome,
Thanks for reaching out here in the Community. We appreciate you sharing your thoughts and ideas however,we don't have any news to share about applying this feature to the Google Home app. We're always looking for ways to improve and we'll take it as feedback. I'd suggest you send feedback to let the Google Engineering team know about your concern. While they won't respond directly back to you, this is the best way to let them know about this.
