10-03-2023 01:26 PM
I built a pool house that is about 300 feet from my house where I have my existing WiFi network and cameras. Since the pool house is too far away for my house WiFi to reach, I had to trench and bury a new cable line to set up a second WiFi network for the pool house. Can I set up the pool house camera (Gen 1), which is on the second network, with my current Nest app or is something else required?
10-03-2023 01:54 PM
Is there a reason you don't want to use the same network name as your house, then the camera should automatically connect to Wifi?
10-03-2023 03:32 PM
David,
I thought that might be confusing and I wasn't sure it would work. I'm also connecting Sonos speakers involving the same issue . If I can just use the same network name and password that would be great.
Joe
