11-14-2021 08:21 PM
I purchased two Floodlight cameras: one for the front and one for the back.
My front floodlight camera works perfectly (both floodlight and cam apps appear in google hub), but my back one only has the cam app. The floodlight still works with motion for 30 sec, but I am unable to manually control the floodlight with the app.
I have tried 1. removing the app from my phone and re-installing and 2. factory reset button (about 20 sec until the camera chimed) on the back of the camera and reinstall the app. Nothing worked.
Any thoughts? Thank you.
12-10-2021 12:33 PM
12-12-2021 07:23 AM
Brad, I am having the same issue here. I saw two threads where there’s no resolution. I have 2 Nest cams with floodlights. Only one of the floodlights shows up in the app. I’ve re installed the camera twice. Is there a fix for this? Thanks.
12-12-2021 09:03 AM
My issue has not resolved. I wish google store had a physical location.
12-29-2021 01:08 PM
Sorry for the late response, just wanted to double check to see if you were still needing help on this? If so, what troubleshooting steps have you tried?
Please let me know.
Garrett DS
12-29-2021 02:46 PM
I've factory reset about 10 times, but I still cannot get the Flood Light and the "battery to the camera would run out" even though it's hardwired.
12-29-2021 11:44 PM
The camera is showing up on the google hub, BUT NOT THE FLOODLIGHT.
01-19-2022 10:15 AM
Just checking in to see if you still need assistance with this issue.
01-21-2022 11:37 AM
Hey Folks.
12-31-2021 07:34 PM
Same issue. Shows up in Home app as a(battery) cam but not a floodlight.
