GJQ9T nest camera not powering on
agshelley
I received an alert this morning that my indoor Google Nest camera was offline. I checked it and it won't power up at all. I've switched outlets, traded out the wall adapter, and tried a factory reset, but still no juice. How can I fix this?
agshelley
The device will not power on whatsoever in any outlet.
I believe that support can assist you further and go over some options for you. Please fill out this form, and a higher tier of support will reach out to you with next steps. As a side note; we unfortunately do not offer replacements for parts. If your device is no longer under warranty, we aren't able to offer a replacement, We're sorry for the inconvenience.
EmersonB
@agshelley we got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. If you have any questions or concerns, feel free to create a new thread as I will be locking this thread after 24 hours.
I appreciate the help Brad.
