Google Nest Cam with Floodlight Losing Power and Saying Extreme Temperature
mrobinet
In April I bought two Google Nest Cameras with Floodlights. I installed them at my cabin in May, one on each side of the house. They both replaced regular floodlights that were functioning well, so the install was pretty simple. About a month ago one of the cameras went offline with an error message saying "Device offline because of extreme temperatures". The day it happened, it was only about 60 degrees outside and the camera on the other side of the house continued to function fine.
The camera on the other side of the house has a different issue. It will say that it has infinite battery, but then randomly run out of battery power and go offline. It will then stay offline was a week or more and then suddenly come back online. Originally I thought maybe someone was turning the switch on and off to the camera, but eventually I removed the wall switch and hard wired it so that it always had power. It still does the same thing. We won't even be at the cabin and it will suddenly lose power and go offline. And then come back online randomly. I know we're not losing power at the cabin because I have other devices that are staying online, such as an Ecobee thermostat and sump pump alarm.
So I then attempted to file a warranty claim, but every link to file a claim just says page not found. How can I get these cameras replaced?
Here is the warranty claim form that does not work:
https://support.google.com/googlenest/contact/warranty_nest?sjid=10788184545943910754-NC
virnab
Hi mrobinet,
Thanks for posting in this community.
I can see that you recently bought two Nest Cams with Floodlights, but one camera went offline with an "extreme temperature" error even in mild weather. Some weeks later, your second camera, even after being hardwired, began unexpectedly losing and regaining power. I appreciate you letting us know these important details about your experience and the troubleshooting efforts you've already tried. I understand this hasn't been a positive experience for you, and I truly regret that. Let's find a solution together.
To assist you better, please answer these questions:
For the camera going offline due to "extreme temperatures":
  • Are your Nest Cams with Floodlights in direct sunlight for extended periods, or is there anything else around them that might generate heat?
  • How far are the Nest Cams with Floodlights from your WiFi router or any WiFi extenders you might be using?
For the camera showing infinite battery but going offline randomly:
  • When you hardwired the Nest Cam with Floodlights, did you use the original power cable that came with the floodlight or a different one?
  • Did you ensure the power cable is securely and fully plugged into the Nest Cam with Floodlights and that it's seated correctly?
  • Are you using the USB cable and adapter that shipped with the camera?
  • Is the end of the cable properly plugged into the camera? Please check if the logo is visible on the USB connector when viewing the back of the camera; the visible logo indicates the USB connector is inserted correctly.
  • Could you please check for any damage on the cable?
  • Have you tried an alternative cable, plug, and socket?
  • Could you please check if the arrow and the G logo are upright in the mounting plate?
Regarding both Nest Cams with Floodlights:
  • Has there been any recent power outage in the area?
  • What is the status of the Nest Cam with Floodlight's LED light?
  • What country are you located in?
  • Where did you buy your Nest Cam with Floodlights?
  • Are your Nest Cams with Floodlights connected to a wired connection of 100 to 240 V AC, 50 to 60 Hz?
  • Is there a ground wire in your installation (copper, green, or green and yellow wire)?
  • Did you personally install the Nest Cam with Floodlights, or was it installed by an electrician?
  • What WiFi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
  • Could you try restarting your WiFi router and modem at the cabin, even if other devices are online?
Please keep me posted.
Virna
mrobinet
Sometimes they are, sometimes not, but it started happening on a 60 degree cloudy day and hasn't resolved itself over a period of several weeks, including at night, so I think that clearly eliminates sunlight as the cause.
Only about 30 feet.
The Nest Cam just had short wires to connect it to the house wiring. A white, black and ground. I used connected all of these to the existing house wiring that worked with the previous floodlight and also check the power with a multimeter and found that it was delivering 121V.
Yes. It is screwed into the camera with the provided screw.
No USB adapter came with the camera. I think you must be thinking of a different model.
There is no damage to any of the wiring.
This is not possible as all Nest Cam wires are not removable without disassembling the camera.
It is.
We do sometimes get short power outages, but have a backup generator that kicks in fairly quickly. Either way, we certainly have not lost power for the last several weeks, so this is not the cause. Even when not at the cabin I know when power outages happen due to other devices going offline as well. The Nest Cam outages don't line up with any power outages we experienced.
White when active.
United States.
Amazon.
Multimeter shows it receiving power at 121V at 60Hz.
Yes.
I personally installed it.
2.4 GHz.
It has restarted during power outages a number of times. This is a device power problem, not a connectivity problem. When online I can view clips and see live feeds just fine clearly ruling any connectivity problems out.
virnab
Hi mrobinet,
Thank you for your timely response and the comprehensive information you've provided. This information is really appreciated so that we can better assist you.
The team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Virna
mrobinet
I filled out the form and submitted it.
virnab
Hi ,
Thank you for your confirmation.
 Please be aware of your email; one of our agents will contact you as soon as possible to provide a follow-up.
If you have any other questions or need further assistance, please feel free to contact us whenever you need it.
Virna
