03-22-2022 12:49 PM
Do the Google Nest Cameras support 802.11r WiFi standard /Fast Roaming and BSS Transition? Been noticing cameras will work for long period of time and then disconnect from WiFi network.
Network is a UniFi DM Pro, with 3 Access Points positioned for coverage after a WiFi site survey.
When the disconnect occurs, the device will be offline for 30 minutes. Tried to unplug power from the device and power back on but would remain offline. Only after no interaction, will the device come back online on its own.
Only thing I could find is that the options mentioned above are turned on and mention devices that do not support this feature may experience connectivity issues. Also, it appears the device enters a power save mode just before the issue occurs, and the Wifi experience drops to the red for the device. Not all the cameras do this, it's only been 1 or 2.
04-30-2022 03:23 PM
Hey CSknTecCMH,
Check out this link for the complete guide on Nest camera set up on your Wi-Fi.
If you have additional questions, feel free to submit another post, and provide as many details as possible so that others can lend a hand.
Hope this helps!
Kind regards,
Ryan
