05-01-2023 08:26 AM
I have had the doorbell just less than a year and after a few problems to begin with it has been working fine until the last couple of times that it has needed recharging. Usually it reminds me via the Home app when the battery is low and then shows as recharging when it's plugged in, both in the app and with the charging light on the unit itself. Now however it doesn't give reminders except when the camera switches off to save power and when I plug the unit in via the USB cable that it came with it doesn't show as charging or have a status light. It does seem to charge when plugged in but a lot slower than it should: 8hrs overnight gave me about 20% charge.
I haven't tried anything to fix this yet. Is there something I can try?
Thanks!
05-01-2023 08:57 AM
Hi @tim_d
Sorry to hear that it isn't charging as it once did. I will send this post over to our community specialists and see if they know of any bugs or known issues.
In the meantime here is a link to the Help Center for the battery doorbell: Troubleshoot low battery issues for Nest cameras and doorbells - Android - Google Nest Help
Jill
05-04-2023 09:30 AM
Thanks @JillG
Did you pass this on as I have had no response yet?
I had already looked though that Help Centre article thanks and not found anything helpful for my problem.
05-08-2023 11:39 AM
I did escalate but I'll give them a nudge right now.
Thanks for letting me know---
05-08-2023 11:00 AM
To update: I had the doorbell on charge after the battery went down to 2%. In over 24 hours of charging I've just plugged it back in and it is saying 46% charged. As with before there was no charging indicator and the Home app was acting as if the doorbell was still mounted on the wall.
Amy help/ideas would be great please 🙂
05-08-2023 11:46 AM - edited 05-08-2023 11:46 AM
Support asked me to clarify these with you @tim_d
05-08-2023 03:09 PM
Hi @JillG, thanks for the update.
In response to the queries:
I'd also like to reiterate that the doorbell doesn't detect being unmounted in the Home app suggesting, maybe, that it's not necessarily a fault with the charging equipment?
05-08-2023 04:05 PM
I'll forward that over to the team...thanks!!!
05-23-2023 05:34 PM
The same thing happened to my doorbell also starting a few weeks ago. It doesn't charge anymore. Feels to me like an update bricked it
05-23-2023 06:19 PM
Thanks for the help here, JillG.
tim_d, thanks for reaching out. Since the steps didn't work on your end, we'd be happy to take a look into this for you. Please fill out this form with all the needed information, then let me know once done.
Juni
05-28-2023 12:38 PM
06-01-2023 09:16 AM
Hello there,
@tim_d, thanks for the update. We got the form you've submitted — thanks for filling that out. Please keep an eye on your email, as someone from our team will reach out to you to assist you more.
@marcel4, have you checked for your Nest Doorbell’s charging port if it’s clean? If not, use a clean, dry cotton swab to clean off any dirt build up on your doorbell’s charging port.
I appreciate your help, Juni.
06-01-2023 03:11 PM
Hey, on my end, I had to factory reset the doorbell, then it started charging again.
Kind of bizarre, but all worked out in the end
06-01-2023 03:38 PM
Thanks!
The problem might have solved itself now. I went away for a week during which time the doorbell (still mounted) battery ran completely flat. On my return I took it off the wall and plugged it in and it charged fine. The charging light was on, the Home app said it was charging and would be fully charged in four or so hours. It has since completely charged, notified me that charging was complete and is now back by my front door and apparently working properly.
I'm not sure why this seems to shave suddenly fixed itself. It may have been that I let the battery completely run flat but I also noticed that once the doorbell was remounted after charging the Home app had been updated while I was away. So whether it was an app update that fixed it I don't know!
06-01-2023 07:03 PM
I’m glad it’s resolved now. I’ll keep this thread open for one more day. If you need further help, let me know.
Juni
