10-09-2023 04:30 PM
Hi nest community,
I have noticed some other posts on this but with no real solution so wanted to try reaching out again.
I have a google nest doorbell (battery) plugged in, and nest aware plus. I have the sensitivity and recording settings on the doorbell set to high.
I understand the camera on the doorbell is supposed to capture events even when NOT pressed. But I find that its ability to record events is VERY inconsistent when not pressed.
I have the doorbell set to detect motion, people, animals, notifications on. I have set a zone for detecting motions which is a wide area.
Some days when I look in the video history, there would be events detected from people and motion that do not involve pressing the doorbell.
However, on many days, I can be waving at the doorbell camera, the green light would be on, but it would not detect it and no event is recorded. When I do press the doorbell, it would instantly register as an event. So I know the wifi connection is good
Has anyone had this issue? I would appreciate any suggestion and solution because otherwise the doorbell works quite well!
Thank you!
10-15-2023 05:31 PM
Hello HallucisLongus,
I’m sorry to hear that you’re having trouble with the Nest doorbell. Let’s check it out.
To completely isolate the hardware issue, let’s factory reset the device. Follow the steps below:
Let me know how it goes.
Lance
