05-07-2022 08:56 AM
Does not recognize when I am home/away.
05-10-2022 02:54 AM
You are not alone, same issue, presence sensing is not working. And has not been working for some time.
I have tried everything, reinstalled all cameras and doorbell, re-installed Google Home, deleted my "Home" and created a new one. And still the presence sensing is not working, the Routine when saying "away" to the assistant does not work either the assistant recognizes the command but does not switch to "away"...
05-11-2022 03:50 AM
Too bad we can not get a definitive answer from Google.
05-11-2022 03:56 AM
I had a long chat with Google Nest support yesterday with no solution.
My topic is escalated to 2nd lvl, waiting for reply.
On the other hand, I did try something different yesterday.
I reversed the versions on Google Home back to an older version 2.49XXX something, i.e., a version released before the beginning of April.
This have actually solved the problem for me, so in version before 2.50XXX presence sensing is working. So it is definitely Google Home which is the problem.
05-11-2022 08:17 AM
Mega Jorg,
How do you "reverse" the version? If I send you my email address would you send me the instructions?
05-11-2022 09:10 AM
Sure do that and I will reply to you.
/Jörgen
05-11-2022 09:14 AM
Thanks.
05-11-2022 09:15 AM
It apparently dropped my email address #
05-11-2022 09:18 AM
Dropped it again. I'll try it this way:
fam dot baize at google mailing system dot commercial identifier
05-14-2022 08:53 AM
OK, I have been working with the people at "Made by Google" in the Messenger system for the last four days. They are either technicians or people with a lot of Google experience. In any case, they are as frustrated as I am with this situation. There apparently is no currently known resolution for this problem. Since presence sensing worked fine with version 2.48XXX, I would recommend that Google roll back to that and then study and fix the problem and the resend the update.
05-14-2022 08:57 AM
I fully agree, as mentioned before directly to you, I use version 2.48.75.6 and that one works.
I was told by 2nd line support, to report this directly in the App by sending feedback, so I did.
Please do the same, perhaps they will notice if a lot of us do this.
05-14-2022 09:07 AM
I did. I used their link. But I did not have the complete version number, I used 2.48xxx. But they should get the message. We'll see. But haven't got my hopes up.
05-27-2022 09:30 AM
Hey Folks.
05-16-2022 08:43 AM
Hey there, folks.
If you need anything else, please let me know.
