Home presence not working consistently
slg49ers
I have started having a problem with the home presence not turning off my camera when I arrive home. It's not all the time but quite often when I get home my camera doesn't turn off. Even after I have been home for a while my phone presence isn't detected and I have to manually turn off my phone. Google home is set to use presence detection using my phones location and my phone is set to always use location for google home app.
Anyone have any ideas what I can do to fix this issue?
Thanks
nerys
Hi slg49ers,
Thanks for posting in the community!
I understand how frustrating it is that the "Home and Away" feature is not recognizing when you arrive home. But no worries; here's help! Let's try a few things to get it working properly:
  • Make sure no other devices are signed into the same Google account and controlling presence detection in your home.
  • If you have a Nest Thermostat, it can also contribute to presence detection using its motion sensors.
  • Check your phone's location accuracy when you arrive home. A strong GPS signal helps presence detection work better.
If these steps don't resolve the issue, this article provides additional troubleshooting tips for Nest Home and Away routines.
If you have more questions, do not hesitate to reply to this post.
Nery.
