How can I get sound notifications on iPhone when events occur?
kh7
my sound notifications on iPhone quit working?
EmersonB
@kh7 aside from restarting your device, you may try going to the settings of your iPhone and look for your Nest app or Google Home app. Go to permissions or notifications and make sure your audio is enabled. Looking forward to your response.
I appreciate the help, Brad.
EmersonB
Hello kh7,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
