11-02-2023 12:58 PM
Hi I've had new hub fitted and can't connect my battery door bell to it.
11-02-2023 02:18 PM
Hi @Mickfen
The easiest way to fix this is setup your new router/hub to have the same settings as your old wifi device.
If this is not possible you need to reset the Nest Doorbell.Check THIS link for more information.
