How to connect Nest (battery) cam to PC?
tobias6304
I have a Nest Outdoor Cam (on battery) I'd like to connect to PC.  Is that possible?
EmptyNester
Silver Product Expert
No, it is not.  This took a lot of people off guard (including me) and only learned this after purchasing the new nest cams.
Jeff
Hey, tobias6304.
Unfortunately, as EmptyNester said, the new Nest Doorbell (battery) is not able to connect to a PC. If you are looking to use a PC connection, you will need to look at a different model. If there's anything else I can help you with, please let me know.
Thanks.
Hey folks.
Hey Folks.
