Installation Height of Nest Cam Floodlight
FergalB
Will the Camera and floodlight work at 5.7m/18.5ft ?
Security lights  we have would be at this height and want to see will this work and can sensors work at that distance.
Thanks
Hey there, FergalB.
The short answer would be, Yes it will. The Nest Cam with floodlight’s camera has a single motion sensor, with 110° horizontal field of view. Motion can be detected from up to 25 ft (7.5 m) away. The floodlight has 2 motion sensors, with a 180° horizontal field of view and motion can be detected from up to 25 ft (7.5 m). All Nest cameras use high-power infrared (IR) LEDs. Nest Cam with floodlight uses 6 high-power 850 nm infrared LEDs and can illuminate a scene that’s up to 20 ft (6.10 m) away.
Hope this helps and we've also shared your feedback with our team.
Jeff
Hi, FergalB.
I just wanted to jump in real fast to see if you saw Brad's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
Hey Folks.
