09-26-2021 01:01 PM
We are replacing our existing doorbell with the Nest wired doorbell. When we took off the old doorbell, there is a hole the size of an outlet box. We need some sort of mounting plate to cover the hole with to attach the doorbell to. Has anyone had that issue and what did you use to cover the hole with to install the new doorbell? Thanks in advance!
09-26-2021 01:14 PM
If you go onto Amazon and search on "nest hello mounting plate" you will see a few options come up.
09-26-2021 03:06 PM
Haven't run into this situation, but there's a Nest Hello NON FLUSH MOUNT Doorbell adapter plate Nutone and M&S intercom sys for $24.95 on eBay that might work for you.
09-27-2021 10:20 AM
I went to a shop that engraves door signs. I gave them the exact size of the mounting plate I wanted and they made one for me, even without getting it engraved. I had them drill a hole for the wires as well.
10-12-2021 03:54 PM
I am terribly sorry to hear about your Nest Camera issue! I can imagine it’s been quite frustrating being without a working device. I would love to look into this further for you.
I will be reaching out to your email on file to collect some information from you. Please respond as soon as you can, so we can get the process started. Please let me know if you need any further assistance!
