01-21-2023 11:54 AM
I attempted to connect my google nest camera (battery powered and wired) to Alexa echo. I was able to do it but decided to undo it since it will not send a notification on the echo, you can just look at the camera from it but it will not notify you. So I removed the camera from Alexa. Now, Im not receiving notifications from the 2 cameras on my phone. I reset and removed them from my "Home" and reinstalled it, changed zones, but still no notification. I can view live feed and i see in the history that motion is being detected and saved but still no notification. I hope somebody here can help!
01-26-2023 10:20 AM
01-31-2023 02:33 PM
@Pjbacero It's us again. I'm bumping up this thread to ensure that everything is covered here. Aside from restarting it, you may try turning off and on your notification settings. Also, please check the notification permission of your Nest app or Google Home app from your mobile device's settings if it's disabled.
I appreciate the help, Brad.
02-02-2023 01:21 PM
Hey Pjbacero,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, I would be happy to keep it open. If there's more we can do, just let us know.
