09-03-2022 11:11 PM - edited 09-03-2022 11:12 PM
Hoping someone can help! I have two IQ Outdoor Cams that I have being using for almost 2 years. We decided to setup everything under a general gmail account instead of a personal one.
I was successful with the doorbell, but my cameras won’t connect to my Nest account. I get the NC017 error.
It picks up the wifi, tests it and then stalls out when it gets to “Setting up the Nest Network” it throws the NC017 error.
Any ideas how to remedy is appreciated. It worked fine for 2 years so this is a bit maddening.
09-04-2022 06:27 AM
You might need to try contacting Google Nest Support at https://support.google.com/googlenest/gethelp to see if they can tell you what an "NC017" error really means. On the Google Nest Help page (https://support.google.com/googlenest/answer/9240048?hl=en#camera_connection_problem&zippy=%2Cnc-err...), "NC017" is one of 34 different "Help Codes" for "Your camera experienced a connection problem". Hopefully, you get a Support person who can tell you EXACTLY what "NC017" means. (Presumably, since Google Nest provides 34 different codes for connection problems, each one has a different meaning,)
09-07-2022 08:30 PM - edited 09-07-2022 08:31 PM
Thanks for your help here, MplsCustomer.
Thanks for reaching out. I'm sorry to hear that and for the delayed response. We appreciate your efforts. Let's sort this out — a few questions: what's the status light of your Nest IQ Outdoor Camera? Did you change your router settings? How far is the camera from the router? What's the make and model of your phone? Also, what WiFi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Try the troubleshooting steps here:
Let me know how it goes.
09-11-2022 07:51 PM
Hi TMDc8,
It's me again. I want to make sure you're all good — how did the steps go?
09-12-2022 08:39 PM
I just wanted to jump in here to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
