Nc 023 on all gen one wired door bell and exterior IQ wired cameras.
zubairmumtaz
Nc 023 error code on all gen one wired door bell and exterior IQ wired cameras. I bought these in 2018 and have added the nest protect, thermostat, home minis, nest hub, batter operated exterior cqmera to name a few. Recently I had to change ISPs and got a new router/modem. Had to connect everything manually however cannot get the first gen wired door bell and the wired first gen nest exterior IQ cameras. I have spent more.like 8 hours including a couple of hours with the nest help but to no avail. These are e all expensive equipment and I would appreciate any help I c any get. I have switched off Bluetooth and restarted, I have forgotten all other Bluetooth connections. I ha r factory reset the door bell 30 times. I have un installed both the nest app and the home app. Today I had a tech come in whom I had to pay he said the first gen models of the cameras have issues with Bluetooth and that perhaps the software on the cameras need to be updated. But how? Pls help any assistance would be highly appreciated. I sunk a lot of money on these. Thanks
Hi Byron, so what I'm about to tell share with you will probably benefit all new Rogers customers in Canada. The nest team helped me figure it out. So the new modems that allow speeds of 1.5ghz need to be configured a certain way by Rogers. Once that is done by Rogers the nest team helped me create a new home on the nest app. And we disconnected the thermostat and the sense from the app before proceeding. It worked finally. Thank you for your support and guidance this took 4 days and probably 10 hours.
The changes to the modem were as follows:
  • Enable 802.11 b/g/n if you have an 802.11 ac router.
  • Set your Wi-Fi router's DHCP lease time to at least 2 hours.
  • Turn on your router's Power Save Mode (PSM), if you have a Nest thermostat.
  • Enable IPv6, if you have a Nest Protect.
  • On your Wi-Fi router, turn on multicast, if you're adding additional Nest devices.
Happy trouble shooting. Cheers
ByronP
Hi zubairmumtaz,
Thank you for posting. I really appreciate the effort to fix the issue and the great troubleshooting that you have performed so far.
The error showing on the screens is because there are issues at the moment with pairing your Nest devices. In order to connect your Nest devices back, we need to do a proper factory reset on your Nest devices to restart the connection and pair the devices again correctly.
Please take the following actions:
Remove the devices from the app. If you didn't remove them at the beginning, here is the link on how to do that.
Then perform a factory reset, here are some links to do a correct factory reset on your devices first:
Factory reset the Nest camera or doorbell. Restart or reset a Nest thermostat. Factory reset Google Nest or home speakers or displays.
After you do a proper factory reset on your devices and the lights are shown correctly, you can add the devices again to the Nest App and Google Home App.
If the issue persists and the code still shows, please take the next action:
  • Quit and restart the Nest or Google Home app.
  • Make sure Bluetooth is on. Turn Bluetooth off, then back on to refresh the connection.
  • Disconnect any Bluetooth devices that are connected to the phone to rule out any interference.
  • Put the mobile device in airplane mode, then turn on Bluetooth and Wifi.
  • Restart the phone or tablet.
  • Restart the joining and assisting devices.
  • Move the joining device closer to the router, or the router closer to the assisting device.
  • Try a different mobile device.
  • Create a hotspot and try to pair again. Make sure that the device connects to the hotspot this time and not the home Wifi.
  • Create another structure in the Nest or Google Home app, and try to add the device to the newly created structure.
  • Note: Use the steps on the link to create a new structure: Manage homes and products in the Nest app.
  • Try to add the device to another account.
  • Reset the joining device to the default.
Keep me posted.
Byron
Hi Byron, thank you for your note. Just an fyi I have tried everything except for the hot spot and creation of new structure which I will today. Also I had the original nest approved installers come in and reconfigure them and they failed. And I had to pay for this service. If this doesn't work out I will try the nest help line and if they can't solve it I will replace these with best competitors as I expect them to work after dishing out thousands of dollars on 6 cameras. Not to mention there are another 7 google devices in the house. This is unacceptable.
ByronP
Hi zubairmumtaz,
Thank you for the post. Sorry for the inconvenience about the issue that you have. Also, thank you for the feedback.
Let me know if this works.
Byron
ByronP
Hi zubairmumtaz,
Thank you for posting. I really appreciate the effort on this. I'll let them know about the insights you provided.
Byron
