09-23-2021 08:15 PM
Hi Nest Hello Experts,
I need some help installing my nest hello wired doorbell specifically chime connector. I've attached my the wiring of my chime here. Because it has 4 wires so there isn't instructions from the app. Thanks a lot!
10-09-2021 01:15 PM
I can confirm that this is resolved. I think I redid the wiring and initially the doorbell worked but the chime didn't sound. I later found that there is the setting in the nest app that controls whether the inside chime sound or not. So the chime worked once I turned it on : )
09-23-2021 08:16 PM
10-01-2021 03:31 PM - edited 10-01-2021 03:31 PM
10-04-2021 03:36 PM
Have a great day.
Garrett DS
10-07-2021 02:00 PM
I actually watched the video and tried to install it but with no luck. The doorbell either didn't get enough power voltage or keeps ringing non stop. So I was wondering if it's possible to point me to which wire I should connect with the chime connector like the instruction does for 2 or 3 wires chimes?
10-07-2021 02:02 PM
My chime is a little bit uncommon I guess. I found this post for the wiring instructions only for the chime to work. But I couldn't tell which wires I should disconnect from the board and connect with the chime connector.
10-07-2021 03:07 PM
I am glad to hear that your Chime is now working! I am going to be transparent with you and state that I do not have a knack for wiring and such, but I know there are help articles on our site, our YouTube channel, and other online resources that are there to help. I hope that you are able to find the assistance you seek.
10-07-2021 03:18 PM
My chime has been working fine. I just can't find a way to connect the nest chime connector with my chime to make the doorbell working.
10-09-2021 01:15 PM
10-14-2021 11:05 AM
I am glad to hear that your issue was resolved! I will go ahead and lock this thread as it has been resolved.
