Nest Battery Camera not able to use Alexa Routines
Jwyatt612
I searched this topic & followed the advice on the older post/question. I can see the Nest Battery camera setup in the Alexa app and can view it live from the Alexa app.
When I try to setup a routine in the Alexa app: Name the routine/select an event/smart home I can choose any of the other Nest cameras EXCEPT the Nest Battery Camera. It does not appear in the list.
Any help appreciated.
ByronP
Hi Jwyatt612,
Thank you for posting in the community. I understand that you're experiencing troubles with a routine with your Alexa app and your Nest Battery Camera. I understand how frustrating this can be. Let's work together for a solution.
For your concern regarding the Alexa App to set up the routines for the Nest Battery Camera, you might consider contacting the Amazon team support for further assistance related to the routines.
Let me know if you have any further questions.
Byron
