Nest Battery Camera will not charge
JoePFromVero1
my nest battery camera recently failed to charge and i am trying to determine if it is under warrenty. is there a way to check based on its serial number? i have a few cameras and am not sure when i purchased this specific camera
12 REPLIES 12
EmersonB
Hi JoePFromVero1,
Thanks for reaching out and bringing this issue to our attention. I'm sorry to hear if it stopped charging. To know more about this issue, I'd like to ask some questions: what is the light status of your Nest camera? Are you able to view the camera feed? Was there any power outage recently? Was there any power outage recently? What are the troubleshooting steps you've done?
Keep us posted.
There is no lights. I have tried 3 different charging cables and none of them result I. Any response. My other 3 nest battery cameras charge and work without issue. There was no recent power outages
EmersonB
Hello JoePFromVero1,
We appreciate you sharing this information. These are additional steps that you can do:
  • While charging, try to reset it to the factory default.
  • If it's still not getting any power, try connecting it to your computer then try to reset it.
I attempted and there is no responses from camera. The camera appears broken and does not respond to any attempte
EmersonB
Hello Dennis7,
Thanks for trying and for updating us — we'd be happy to take a look into this for you. Please fill out this form with all the needed information. Let me know once you’re done.
We haven't received your form. Were you able to fill it out? Do you still need help?
Thanks for your help, Emerson.
aatienza
It's us again. Do you still need help with your device? If so, please fill out this form.
Archie
Thanks for chiming in, Archie.
Sorry, I was traveling.  I submitted the form you sent me for two cameras that not longer respond.  I am near the coast in a salt air environment.  Are Therese cameras susceptible to failure from the salt air.  The previous version of these cameras with attached cables seem to last much longer for me.
i have four other battery cameras in the same location and i am worried these will have the same failures
It doesn't specify whether the cameras are susceptible to failure from salt air. We got the form you've submitted, and we'll send you an email about your concern. Please keep an eye on your email as someone from our team will reach out to you to assist you further. For anyone who is experiencing the same issue, reach out to us here.
