Nest Cam Battery charging
PatriciaMalanco
How do I connect my NEST CAM BATTERY directly to the mains to charge it, instead of just using the battery?
@PatriciaMalanco
We've had our battery camera plugged in with the 10-meter Google Nest optional power cable for 2 years now, purchased from the Google Store (https://store.google.com/us/product/nest_cam_weatherproof_cable?hl=en-US).
If your camera is already running and you are adding a power cable, you may have to remove your camera from the Google Home app, do a factory reset, and reinstall it, in order to get the camera to recognize it is plugged in, according to other posts in this forum.
2 REPLIES 2
@PatriciaMalanco
RenzJ
Hi @PatriciaMalanco,
Checking in — did you get a chance to try the steps shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
Renz
