09-23-2023 07:36 AM
Today, for some reason my Nest Hello Wired Doorbell has stopped functioning as it should be.
The camera turned itself off today (11:38am) and I've not been able to get back into it since (3:33pm), not even after resetting the WI-FI to see if that was the original problem. I have attempted to reset the device by holding down the reset button at the back of the unit, that didn't help.
I've noticed the Doorbell is very warm and there is a buzzing sound coming from the unit itself (I have never noticed this before) so to be safe I have temporarily disconnected it from the power which is a little inconvenience as it on my downstairs lightning ring so I've had to shut the breaker off via my consumer unit.
I am going to give it half an hour or so to see if it cools down and then I will pop it back on to see if that has helped or not. I suspect it won't, but I am trying to be hopeful.
Has anyone else experienced anything like this before?
09-23-2023 12:58 PM
If you have a Nest Hello Doorbell, you need to press the reset pin on the back of the doorbell AND the big doorbell button on the front for 10 seconds:
09-25-2023 04:42 PM
Hello RyanC07,
Checking in — did you get a chance to try the steps shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
I appreciate the help, @MplsCustomer.
Edmond
