Nest Cam Indoor not powering on
Sarool
I have a Nest Cam Indoor, model GJQ9T, that turned off and will not power back on. I have tried a different outlet, a different USB plug from one of my other Nest cameras,  plugging the USB cable into a computer and other USB power sources, and pushing the reset button while it is plugged in. None of this has resolved the problem. I can't try another cable because it is integrated into the camera. Please advise.
ByronP
Hi Sarool,
Thank you for posting in the community. I understand you're having trouble with your Nest Cam Indoor that doesn't power on. I appreciate all your troubleshooting efforts you've already taken. I'm here to help.
For better assistance, please respond to the following questions:
  • Did the Nest camera work when it was first installed? If yes, how long has it been since installation?
  • Have there been any recent changes made to the camera's setup, settings, or app?
  • Is the camera paired to a Nest Account?
  • Is the Nest camera’s cable securely connected to the power adapter?
  • Are there any kinks or frays in the cable?
  • Where is the device installed?
  • Have you experience any power outage recently?
Please keep me posted on your findings.
Byron
Sarool
Yes, it worked for several years after installation.
No changes to its settings or location.
It was paired to a Google home account
No damage to the power cord.
Per my original post, I performed troubleshooting on the cord and power adapter.
The camera was in a window, not in direct sunlight.
No recent power outages.
ByronP
Hi Sarool,
Thank you for your reply. I appreciate all the detailed information you've provided. Let's work together to find a solution.
The team would like to learn more about this behavior. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Byron
