01-25-2022 03:59 AM
Hello there
Hep please! I bought my Dad 3 Nest Outdoor cameras, he already has motion sensors set up after a burglary that really affected him. (Its FM4000E Alarm System by FM Electronics Ltd). We set one camera up to start with and everything was okay for almost a week, but then the motion sensors started alarming. We have now turned off the Nest Outdoor camera and the motion sensors are fine again. I’m at a loss as to why this has happened but assume its the wifi signals? Any ideas how to be able to use both the cameras and the motion sensors at the same time or is it not going to be possible?
If not possible what are my options for other cameras that will work with the motion sensors?
Thank you in advance
Claire
01-25-2022 07:15 AM - edited 01-25-2022 07:16 AM
It wouldn't be wifi. Does this happen only at night? If so, I would guess it's the Infrard LED's in the camera that turn on. That's how it sees in the dark. Some motion sensors are implemented using IR either completely, or in part. It shouldn't really cause any issues, but depending on where the camera is pointed, and objects in view, I guess it's possible that illumination might change in ways over time (wind, etc) that could trigger motion sensors. You might see if there are ways to reorient the camera a little to see if changes things.
01-25-2022 10:33 AM
Thank you so much for replying. Yes it was on a night. So the motion sensors are inside the house pointing inwards (in other rooms) and the Nest Outdoor Camera is on the outside of a window fixed in to the frame (the camera is pointing out to look for people on the outside of the house). If you still think its IR I guess we could move from the window frame and fix in to the outside wall? Do you think thats worth a shot?
thank you
01-25-2022 10:50 AM
Hmm, that doesn't seem likely then - although I'm at a loss on what else it would be. Are you sure about the relationship between turning off the outside camera and the motion alerts? Is it possible that was just a coincidence? I'd be inclined to turn the camera back on, and see if they return consistently over multiple days. If they are IR motion sensors, I guess it is possible that there is some IR leaking through the window. That would likely require open curtains, or otherwise a fair bit of light leakage. IR is just light that you can't see, so if you can see visible light through the window, IR is coming through as well. If there are motion sensors close by that window, it's possible it could set them off.
In terms of the camera position, I was thinking of first just trying to turn the camera a little (but keep in view what you want to see) to see if the IR leakage through the window reduces and maybe avoids the issue.
01-26-2022 04:38 PM
Fantastic, thank you, let me try your ideas and see what happens…I’ll report back!
03-27-2022 03:40 AM
Hi firmwaredev, we’ve repositioned the camera and all os working fine, in fact we’ve put another two up and no issues! Thank you for your support x
03-28-2022 11:02 AM
05-12-2022 12:35 PM
Hello @ch01mes84,
Just wanted to check in here to see if you were able to see John's response here? Did you have time to dive into the issue you are having? Please keep us posted if you need anything else.
James
