Nest Cam and floodlight using a power adapter plug
R0nandavey
Can i simply use a power adapter plug - per my existing security cam and wire my Nest Cam and Floodlight to that?
@R0nandavey
We have the Google Nest battery camera, plugged in with the optional power cable. The camera that's part of the Google Nest Floodlight fixture is the same camera, but in the floodlight fixture the power cable for the camera is connected to the rest of the floodlight fixture, which in turn is connected to a standard household circuit.
I suppose you could run the same power cable we use to the camera that is part of the floodlight fixture, but that wouldn't power the floodlights and associated circuitry that is part of the fixture. And I suspect you wouldn't want to try to rewire the fixture to run the floodlights through the kind of power adapter that is part of the optional power cable that powers just our battery camera.
EmersonB
@R0nandavey, thanks for reaching out here in the Community. How's it going with your Nest Camera? Were you able to read the information that MplsCustomer has shared? In case you have an update, you know where to find us.
EmersonB
Hello R0nandavey,
I'm dropping by to ensure that everything is covered here. How's it going with your Nest Camera? We would appreciate it if you could share the information I’m asking above. We'd be glad to hear from you.
EmersonB
Hey R0nandavey,
Just one final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
