11-05-2022 01:27 PM
I am trying to factory reset my nest cam to connect it to a new Nest account but the pinhole reset simply doesn’t work. There is no button to press or at least no sensation that it is being pressed. I hold a thumbtack in the hole for 15-30 seconds and no lights flash and I get no reset tone. Any solutions?
11-05-2022 01:56 PM
I've had better luck on reset buttons in general with a paper clip (because it's flat on the end) than a thumbtack, and sometimes you can't feel the reset button being depressed. Is the camera plugged in while you're trying?
https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-cam-iq-indoor-or-outdoor
By the way, have you first removed it from the old Nest account while logged onto the old WiFi?
11-05-2022 05:58 PM
Thanks for the reply. I just tried a paper clip and no luck. It feels like I’m pressing up against something solid. Yes the camera is plugged in and I removed the device before trying to migrate it to a new nest account. Not sure what else to do..
11-22-2022 09:55 AM
Just checking in to see if you have filled out the support form that @aatienza shared. Please let us know if you have any further questions or concerns. We'll leave this thread open for a little longer for follow-up questions and concerns.
11-23-2022 10:19 AM
11-10-2022 10:15 AM
Sorry to hear you're having trouble resetting your Nest camera. It seems that if the device isn't capable of resetting, you may want to get support involved. I would invite you to fill out this support form, and a higher tier of support will reach out to you with next steps.
11-15-2022 06:13 PM
We haven't received your form. Were you able to fill it out? Do you still need help?
I appreciate the help here, MplsCustomer and Brad.
11-18-2022 06:49 PM
It's us again. Do you still need help with your device? If so, please fill out this form.
Archie
