4 weeks ago
During a snow event my Nest Cam with Floodlight triggers the floodlight. The light stays on until the snow stops. I have adjusted the motion sensitivity down to Low and this does not solve the problem. Please help.
3 weeks ago
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. We’re always looking for ways to improve, and appreciate your feedback. You can send it at any time using your devices, following the steps found here. In the meantime, lowering your sensitivity was a good choice. I believe that Activity Zones will help you out in this situation. You can learn more about them here. I hope you find the article helpful. Please let me know if you need further assistance.
3 weeks ago
@tripbates how's it going with your Nest Camera? Were you able to read the information and check the links that Brad has shared? In case you have an update, you know where to find us.
Thanks for answering, Brad.
2 weeks ago
Hello tripbates,
2 weeks ago
I am also having this issue. This is simply an issue with what Google believes to be headlights streaking across the screen, when it is just a snow flake. Here in Denver I have this issue across two nest floodlight cams any time it snows. It's so easy to reproduce it's silly. I can share footage with your qa or dev team but your image labeling models need some serious improvements during heavy snow and rain.
2 weeks ago
You can try to lower your sensitivity, as that has helped for other users in colder climates with lots of snow and rain.
2 weeks ago
Its been on the lower sensitivity for a while and that does not help. When it snows heavily, it goes off every 3-5 minutes. Also, even if that did work, I hate to set the sensitivity to low just to handle snowstorms.
2 weeks ago
2 weeks ago
2 weeks ago
rreynier, we got the form you’ve submitted. I’ve checked your case and our team has sent you a follow-up email for further instructions.
tripbates, how’s it going? Still need our help?
Thanks for the help here, Brad and Emerson.
a week ago
Hello tripbates,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
a week ago
Certainly not fixed yet 🙂 Only a software update will fix this.
