10-08-2022 07:00 AM
My camera is on and I am trying to charge it with the cable. For some reason it will not charge beyond 52 percent after trying for a 12 hour period. What's wrong? What should I try? Thanks.
Flyer
10-08-2022 08:25 AM
Is your charging cord plugged in with the cord feeding towards the FRONT of the camera and is the plug fully seated? Is the LED status light pulsing white, indicating it's charging? https://support.google.com/googlenest/answer/9268073?hl=en#zippy=%2Cgoogle-nest-cam-battery
I've seen other reports where either the battery camera or the charging cord was defective. You could try contacting Google Nest here: https://support.google.com/googlenest/gethelp
We've had a Google Nest Camera (Battery) plugged in with the optional power cable and it always stays charged, so yours SHOULD charge; Google Nest says it should take 5 hours to fully charge the battery (https://support.google.com/googlenest/answer/11052520?hl=en).
10-11-2022 11:13 PM
I just wanted to jump in real fast to see if you saw MplsCustomer's reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks for your help, MplsCustomer.
10-15-2022 07:15 AM
I appreciate the help, JT.
Archie
10-16-2022 03:44 PM
Archie
