Nest Camera Battery Unmounted Error after charge
BradyTheWriter
I have taken my nest camera down to charge. It's on a magnetic mount. Fully charged it and remounted it. Now when I try to verify that it is working I get unmounted error. I've tried resetting by uninstalling and hitting the button for five seconds but no luck.
@BradyTheWriter
I don't know why your battery camera is no longer recognizing that it is mounted. (We've had a battery camera for over 3 years, but ours is already plugged in.). However, holding the reset button down for 5 seconds performs a "Restart" only. See the "Factory reset" instructions later in the Help topic; they call for pressing the reset button for at least 12 seconds.
https://support.google.com/googlenest/answer/9252162
BradyTheWriter
Thanks. Did the factory reset and reinstalled. The camera was fine while performing the installation, but once I mounted it back to where it was, I got this message: Live video unavailable. The camera may be unreachable or saving battery.
@BradyTheWriter
I don't know why Google Nest chose to lump "unreachable" and "saving battery" in the same error message.
Perhaps you have a defective camera; you could try contacting Support:
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
