05-10-2024 12:25 PM
Changed Wifi recently and I have three Nest Battery Cameras I am trying to connect. One is bricked - has not turned on in 6 months. Lets put that to the side for now. The other two were working fine prior to this Wifi change. I did not remove them from google home but instead I deleted the old home and made a new one.
Current state. Both cameras start the setup process but then I get the error that something went wrong. I have tried restarting the cameras, and factory reset the cameras multiple times. At this point I am out of ideas.
When the camera completes its factory reset the light changes to green (no blue like I think I need).
Please help!
05-10-2024 12:48 PM
Are you holding down the reset pin/button for at least 12 seconds, as described in the "Factory reset" instructions on the page below (not the "Restart" instructions)?
05-10-2024 12:58 PM
yes!
it makes noises etc and the light goes white for a moment. Now its back to green.
05-10-2024 01:06 PM
another note is it appears to be working as it would if it was setup. AKA the light goes green when it detects movement. But again this camera is not connected to the google ap.
05-10-2024 06:20 PM - edited 05-10-2024 06:20 PM
on the 5th attempt to factor reset this started to work. Thanks for the help.
05-10-2024 06:22 PM
Yeah, sometimes factory resets are tricky.
