05-27-2024 05:16 PM
So I already have around a dozen cameras for my property
I have been running these off the solar panels for quite some time
However, now that my house is getting more set up and I am in a better position, and now that the solar panels are starting to die after a few years, I am thinking of swapping them out for the floodlight bases.
The Cameras work fine without any issue, however, given that the solar panels are dying, I want to swap out for the floodlight base
I have one Google nest cam flood light base, and it works Phenomenally
However, I am struggling to find where I can just purchase the bases, As I already have the expensive bit being the camera.
I don't need any more cameras
05-28-2024 09:41 AM
I've never seen any listing where Google Nest sells the floodlight base separate from the camera.
I'm not sure what you mean by swapping out your solar panels for the floodlight base. Are you planning on running electrical power to your cameras? If so, you could get the optional power cables: https://store.google.com/product/nest_cam_weatherproof_cable.
We've had a battery cable (it's the same camera used in the floodlight camera fixture) since Sept. 2021, plugged in with the optional power cable, and it's been "live" and online ever since.
