03-29-2023 06:32 PM
This will be the 4th time I bring this matter up and still no resolution as to why 3 of my wired camera's (one does not even turn on anymore) and one battery camera do not connect (either C104 or C119) which is totally wrong as I have another 3 battery cameras further away from the router which have never given me an issue. As for C104 my password is correct each time as I check same.
I am not sure how to relay this issue directly to Google - have tried chat and call back feature only to be hung up on or told to call back as no one to make the call-back, the customer experience for me has been really bad as I would assume that someone from Google is also filtering on this exchange?
Anyway if someone knows how to relay messages or calls to Google so I can get this sorted it would be appreciated noting I have tried all suggestions provided on the community forums to no avail and I will trash the cameras if Google cannot help. A total waste of time and money at this stage.
Thanks
03-30-2023 09:27 AM
I'm just another Google Nest customer, but it seems the only way to contact Google Nest Support is to start with this link:
I don't know how you would get a C104 or C119 error when trying to reinstall your Google Nest Outdoor Cameras unless you previously had them installed with different Wi-Fi credentials and did not first do a factory reset to get rid of the previous Wi-Fi credentials (see factory reset instructions after the restart instructions: https://support.google.com/googlenest/answer/9252162).
If you are having problems keeping four of your cameras connected, my suspicion is that Wi-Fi issues of some kind MIGHT be the problem, since it's unlikely that 4 different cameras would all fail at the same time.
I don't know what Wi-Fi issues to look at, since we don't have any issues with our cameras, doorbells, or Nest Hubs. But on this thread a couple of customers discovered they needed to turn on "Self Organizing Network" and turn off "Dynamic Frequency Selector". We don't even have those options on our Wi-Fi router.
04-05-2023 07:27 PM
Checking in — have you tried to factory reset your cameras as shared by MplsCustomer? If so, how did it go? Let me know if you need more help.
I appreciate your help, MplsCustomer!
04-08-2023 08:32 PM
Hey TonyL,
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
04-10-2023 03:50 PM
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
