Nest Doorbell Battery Base Plate.
edlopez2
I'm looking to purchase a replacement metal base plate for the Nest doorbell battery. When moving across country it looks like we've bent it  and now doesn't click when mounting, so I can't get a stream. Any advice would help. I dont want to have this device become useless because a metal mount, I 3d printed and 1:1 replacement but it didn't work I'm guessing because it was plastic.
Louisb1763
I'm was the same boat. Support wasn't very supportive. I ended up going with arlos for front and back.
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
Hey Folks.
