Nest Doorbell Battery Metal Backplate
Anjuna0228
We moved recently and can’t locate the metal backplate for the camera. The device won’t work without it. I’m having trouble trying to figure out how to get a replacement. Thanks
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
