Nest Doorbell Battery Wired to Chime 110V
Steven26
Hi, please, somebody help me, I need to connect a Google Nest Doorbell to a chime of 110v. How do I connect the transformer to 24v without affect chime voltage?
2 REPLIES 2
sterlinghawk
Is your transformer already installed?  More than likely it is and is already connected to the chime systems.  Generally this is always done when a house is built.  Just take off your current doorbell and install the Nest doorbell .  Not all wires will have a red in it or black to indicate power.  Since doorbells are low voltage some are other colors.  For example, I just worked on mine today.  Green/Green White is ground.  Blue/Blue White is your power.  Find your transformer and see if it is connected via the above colors.  🙂
Lance_L
Hello everyone,
@Steven26, thanks for reaching out to the Community. I’d be happy to help you with your questions about wiring the Nest Doorbell (battery).
Here’s a video guide to help you set up the Nest Doorbell (battery) with a wired installation.
If you still need help, a local pro installer or trained electrician can install the doorbell for you.
Keep me posted.
I appreciate your help, @sterlinghawk.
Lance
