Nest Doorbell (Battery) is not charging and is unable to reset.
Vader_181
I apologize for the long story. My Nest doorbell has been functioning fine for the almost 2 years I've had it. Yesterday I went to charge the doorbell since it was a little low on battery. It made the usual audible sound when connected to a power source. After a few hours I looked at the Google Home app to see how much it had charged and saw that it was offline. I went to the doorbell itself and pressed the doorbell button, which usually gives you the percentage it is charged, and got nothing. I unplugged and replugged the doorbell and no longer heard any indication it was charging. I tried a different charger and still got nothing and the doorbell remained offline. I tried remounting the doorbell to see if it would at least power on and it did not. I then tried resetting the doorbell to factory conditions and got no reaction from it. The doorbell is essentially a brick right now. Has anyone experienced something like this?
Jay
@Vader_181
I've seen other posts like yours in this forum, where the battery doorbell quit working and could not be factory reset. You could try contacting Support:
