a month ago
Does anyone have a good source for Net Cam IQ power supplies and cable replacements? I have three dead power supply pucks that need replacement and would like to purchase a few spares and cables. Google has discontinued production and sales. You can get replacement power bricks through Google if you have several hours to go back and forth and have a sturdy enough walk to bang your head against.
a month ago
From a post here on this forum back in 2022 I found some said this works as a this replacement for the IQ cams
https://www.amazon.com/dp/B09C5RG6KV?ref=ppx_yo2ov_dt_b_product_details&th=1
a month ago
So the wattage rating on any power supply is the MAX it can deliver. The device plugged into will only pull the number of watts it needs. The thing that is important is that the voltage rating is correct for any device as supplying to many volts can indeed hurt a device.
a month ago
a month ago
Thank you. I will check it out. The existing power supply pucks are 28W, so I need to be careful not to fry the camera since this one is a fast charger up to 65W (Anker USB C Charger, 735 Charger (Nano II 65W)).
Still need to find cables as well. May have to try eBay.
a month ago
4 weeks ago
Thank you.
